- May 18, 1997
Intel Core 2 Duo & Extreme Power Consumption - Are you wondering if Intels new Core 2 Duo and Extreme are raging infernos like their predecessors? We show you what kind of wattage you can expect to draw so you know what PSU is in your future. And we throw in AMD's Energy Efficient 3800+ as well.
What we are going to do today is actually very simple. We have tested the very similar systems and measured just how much power it takes to run each system under different work loads. We do this by plugging our power supply into a device that sits between the power supply and the wall socket. This device will report to use the wattage that the system is using. We then take that data under different loads and simply report it to you here.
