Intel Clarkdale question
polonyc2
I'm confused about Intel's upcoming dual core Clarkdale CPU's...I know they will have integrated graphics but will I be able to disable this and use my own dedicated video card?...the new CPU's sound really nice for gamers...especially since all the current i7's and upcoming Westmere CPU's are not targeted for gamers...I would love to upgrade my E8400 to Clarkdale
I would think that disabling the integrated graphics would be possible but I havn't found any definite information on this...anyone know for sure?
you can always disable integrated graphics. In fact its usually a default for it to be diabled automatically by the BIOS when then BIOS detects a graphics card.
but after reading a few Clarkdale articles I read that disabling the integrated graphics would not be so easy as the whole piece of silicon can't be disabled because it also contains the PCI-Express and memory controllers
so it seems that disabling it if it detects a discrete graphics card is not the same as having a system with a non-integrated graphics card
you can direct the iGPU to stop doing iGPU stuff. Beyond that, whats it matter?
