Intel Centrino (Laptop) Overclocking...
pugsley1218
I have a new M1710. I just want to know if is possible, to change the clock speeds on the CPU or the Geforce Go 7900GTX. I know it isn't smart to OC laptops, but still, I want to see.
keep in mind Laptops have so little air flow and space.. Why OC the laptop ? I think your better off on a desktop to OC more advantage and less stress to worry about
tried coolbits or another oc software for the 7900gtx go? should work.
Which CPU do you have? Has anyone tried pinmodding a Yonah yet?
DISCLAIMER:
The above was a joke. I don't recommend it, as I don't believe pinmodding does anything for Yonah. You will probably damage your processor if you try.
Just listen to the above poster, and download Coolbits or Rivatuner for your GeForce.
I dont think coolbits works, because it uses those knew control panel nvidia drivers.
and rivatuner looked weird and showed both memory and core at 100mhz, so that cant be right.
