To start I will name my system specs.
ECS 915P-A rev 1.2
Pentium 4 640 OEM
Compusa 400 watt powersupply
1 gb ddr2 kingston 533
mx440 vidcard
CD/DVD drive samsung
zalman 9000 alcu heatsink w/ 775 kit
I was putting the system together yesterday, and I had put the cpu, heatsink and ram in, then I booted it to make sure everything was in right. It booted fine, so I attached everything else, and when I went to boot it, it gave me the please connect bootable medium message, so I hit enter and the system shut down. I went to boot it back up and the lights on the heatsink and the case fans lit up for a second then died.
I tried it again and it did the same thing. So I took everything apart and started from scratch. It booted up fine again. Then it would do the flicker thing when I tried to boot it again.
I am unsure what is wrong. The powersupply even though it is a 20 pin, should still be able to power everything. It booted twice.I am pretty sure nothing was fried because it booted up after it had flickered a couple times. I used arctic silver 5 between the cpu and the heatsink. I dont think it is a grounding problem, otherwise it wouldnt have booted the first time.
Do you guys have any ideas? I have built many systems, but they have been amd. I read the instructions that cam with the MB and I am pretty sure I didnt skip anything.
Thanks in advance.
Jonathan
ECS 915P-A rev 1.2
Pentium 4 640 OEM
mx440 vidcard
Thanks in advance.
Jonathan
