Intel Bios problem {URGENT}
Ikrit
I just updated the Bios on my new (self-built) computer, and it won't recognize my hard drives.
Please help!
Intel D856PERL
No
Not SATA, just basic old Parallel ATA.
I need this computer to work tonight, if possible.
One's a 160, other's 80. Both have separate windows installations, but I have the Master as the one I want to use.
When I go into the BIOS, it says I don't have anything on the Primary PATA channel, but both the drives are plugged in on that.
Check the orientation of your IDE cable (red stripe goes to pin 1, plus the cable and drives should be keyed to show you the correct orientation).
This usually doesn't matter, but make sure the master drive is at the very end of the cable, slave drive in the middle, and while you're at it make sure the cable is plugged into the motherboard correctly. Also double check your jumpering (master/slave).
If you have an extra IDE cable, try swapping cables just to see if that helps. Preferably you want UDMA 100 or better cable.
Make sure both hard drives have their power cords plugged in completely (you should hear them spin-up when you hit the power switch even if they're not recognized in the BIOS).
You might try connecting them to the secondary IDE controller, just to see if they're recognized in the BIOS then. (if this is the case, your primary IDE controller may have bit the big one).
You can also try connecting just one drive to the IDE cable to see if that works. Just FYI, if they're Western Digital hard drives and you try this, you'll probably need to completely remove the jumper as most Western Digital drives require the jumpers to be 'open' when they're on an IDE chain by themselves.
Good luck.
Pin 1 is usually upper left, right?
I'm currently trying to flash the BIOS from a floppy to see if that works, but I can't get the Floppy drive to work. The computer was running fine three hours ago, then when I updated the BIOS (case stayed closed) it suddenly stopped working. I doubt it's a cabling thing.
Pin 1 is typically in the upper left, yes.
Does the computer go through the POST sequence, and do you see the main POST screen when it is running?
If not then yes, you may have a bad BIOS flash, and depending on the board, you might be toast.
Yes, it does do the POST thing. It just tells me, after POST,
"Please restart and select correct boot device or place media in selected boot device.", or something to that effect.
I have an OEM Intel D865PERL from Newegg. Would I be able to RMA?
Thanks for the help.
the hard drive and floppy DO work in another computer, correct?
but yeah sounds like the BIOS might have fried
Newegg has different policies on motherboards...but I think if it's within a year you can RMA. If not, then intel should be able to get you another one..
It works fine now. Just loaded "Optimal Defaults" in the BIOS settings and then stared at the screen looking at the pixels in the WinXP login window for a good 30 seconds before thinking; "Why is it asking me to log in?". I'm really tired.
Depending on how long ago you bought it, you may be able to return it to Newegg. However, before you go that route you may want to try a couple of other things:
1) First clear the CMOS.
2) I took a quick look at the manual for your board (available via pdf if you don't have the papter copy: ftp://download.intel.com/design/motherbd/rl/C3176401.pdf )
Section 3.8.4 (page 92) is titled 'Changing the Default Boot Device During POST'. A quick excerpt:
"Pressing the <F10> key during POST causes a boot device menu to be displayed. To use this key during POST, the User Access Level in the BIOS Setup program's Security menu must be set to Full. The menu displayed after pressing the <F10. key lists the available boot devices (as set in the BIOS Setup program's Boot Device Priority submenu)."
It goes on to show some options, but it sounds like that might be your best bet. Another thing too, you might wish to enter the BIOS just to see if your hard drives are being identified It should be listed under a menu that says something like 'Standard CMOS Features'. If your drives show up under that menu, then the problem isn't that the drives are not being identified - and it probably has to do with selecting the correct boot device as we were discussing in the previous paragraph.
Good luck.
I'll leave my previous post there because it might help out somebody else having the same problem some day...but I'm glad you got it working! :)
I guess Intel boards are really picky about the boot options. Good work :)
