- Dec 19, 2005
"Unfortunately, regardless of the SKU or consumer motherboard choice, the platform will not work, and the CPU will not boot, as Intel has restricted "Bartlett Lake-S" to keep it away from consumers. Companies like ASRock have confirmed that the "Bartlett Lake-S" Core 200E will not be available for consumer motherboards and will only be used in the embedded and edge computer sector. This means you can technically buy and use this CPU for any Windows or Linux task, including gaming, but you will have to go through a process of acquiring an industrial-grade motherboard or a mini-PC that suits this platform. This means gaming support will be limited, as Intel explicitly will not bring any optimizations like APO/IPO to the platform for gaming. Instead, it will be treated as a generic x86-64 Intel CPU, just like any other processor. Extracting the maximum gaming performance could also be problematic, as there could be compatibility issues, given that Intel has envisioned other applications for this platform."
Source: https://www.techpowerup.com/346875/...s-wont-boot-on-consumer-motherboards#comments
