Intel BadAxe (first gen) CPU question, and ram question.
ToxicBanana
I wanted to upgrade as I got this system about 18-20months ago when it was new.
1.-Can this do SLI? (it says it can do the ATI crossfire but no mention about SLI)
2.-Can this use the Intel Quad Core? (I have a E6600, and wanted more cores for 3DSMAX and Realwave)
3.-In Vistas 64bit, with 8GB of ram, (is that too overkill [my options are currently to keep my 2gb and add 2gb more which would be another $70, or drop it for a 8gig pack for $200] and, I like instant Alt+tabs when gaming or others.
4.-Any idea if this motherboard can use the new Quad Cores coming out?
Thank you for all the help.
Oh, and off topic, how much do you think I can sell a e6600 and 2gb of Corsair XMS 800mhz for?
Had this board...No SLI...as long as it's the d975xbx2kr it can run the quad 1066 cpu's...iirc no support for 1333 cpu's...I alt-tab no problem with 4gb on vista ultimate. This board is awesome for stability...at least that's the luck I've had with them.
kinda weird on the 1333mhz, as I have had my e6600 clocked at that for some time now. OC that is.
I don't know for sure, but I would doubt that the first-gen Bad Axe would support 1333fsb chips. Check Intel's site for an updated BIOS and see if they have one out that supports them.
