Help.
I have an Intel Bad Axe 2 w/ E4300, Arctic Cooling Freezer 7 Pro, and Windows Vista 32. The e4300 is moderately overclocked (2.3ghz) and I'd like to reduce the CPU fan speed (to ~1200rpm) in order to minimize noise. Right now the fan runs at a constant 34 degrees and 2140 rpm unless I use IDCC to reduce it manually; The MB will not throttle the fan automatically. Is there anyway to control the fan speed from the BIOS without using IDCC (it's not Vista compatible :-()
Thanx ... msg
Thanx ... msg
