Intel Arc GPU Driver Issue - Citrix Workspace
NobleX13
I have been troubleshooting a Citrix latency issue when accessing my virtual desktop from home for weeks if not months now after moving to an Intel Arc A750, and it turns out this is a known issue that has been going on since September 2023 with no resolution yet.
https://github.com/IGCIT/Intel-GPU-Community-Issue-Tracker-IGCIT/issues/522
I ended up importing the .admx for Citrix Workspace to my local machine and disabling Hardware Accelleration.
Administrative Templates > Citrix Components > Citrix Workspace > User Experience > Hardware Acceleration for Graphics
After doing this, my ICA RTT latency dropped from 200ms with spikes into the 600s to a stable 59ms.
Did you try h265? Might perform better if the default encoding isn't supported by the A750 or the server hardware.
intel arc really shouldnt be used in anything mission critical, for reasons like this...
Hi, I was having this issue with integrated intel arc graphics. I got as far as here but there's no Hardware Acceleration option even present. Any tips would be appreciated.
Edit: Nevermind, I was on the local machine. Got it figured out. Thanks for this solution!
