Intel 915 vs AMD 3400 939
IceDigger
How is the intel 915 cpu compared to the amd 3400 939 cpu?
Thinking of which to get.
915 all the way....!!!
Not because it's better then AMD's 3400.... ;) It's because it's got an uprade path...
S939 is DEAD!!!! You'd be locking yourself into outdated technology. All new Intel based mobos support Pentium 4 D's, Core 2, and most likely Quad core CPU's coming out in November.
IceDigger said:
Is it faster?
It will be in multithreaded applications. It is a dual-core compared to single core 3400.
That's what you gotta look at.
To sum it up, 3400 will be faster (not by a huge margin byany means) in "general" Windows use and most of current games. More and more software will be multithreaded from now on, and will definitely perform better on dual-core systems.
If this is a new build, Intel is the way to go. Again, S939 is dead. No upgrade path at all.
So if you choose 915 for it's upgradibility path, but are still concerend with performance, just overclock it to 3.5~3.6 and it will be faster then 3400. Later on you can pop in dual-core E4300 (Conroe CPU coming out in Jan 07) and OC the hell out of it, leaving all Netburst P4's and AMD's X2's in the dust.... :eek: :D Sure you can OC 3400, but again, no upgrade path, old tech, etc... That's the point I'm trying to convey.
Good luck deciding... :cool:
