intel is comming out with 4 channel memory to in there socket 1567 with 8core cpu's Nehalem microarchitecture. http://en.wikipedia.org/wiki/Xeon#Beckton
you might want the kids to go in the other room before you check prices.
Becton uses a new socket and has a 4-channel memory controller. Its closest competition on the AMD side is Magny-Cours, which will definitely not be coming to desktops, so there's pretty much no chance of that happening with Beckton either.It looks like Beckton will replace Dunnington, which means these are strictly 'MP' processors and likely will never see desktop or workstation-level incarnations. We never saw a Core2 hex-core in S775 or S771 but it does exist with the Dunnington 7400-series Xeons. Of course, things can change if AMD pushes 8-core processors to the lower end markets quickly. Intel will definitely follow suit, you can bet on that.
My thoughts exactly. Octal cores will come to the desktop/workstation markets using different motherboard architectures. At this point, I have no idea what that will be for either manufacturer.Becton uses a new socket and has a 4-channel memory controller. Its closest competition on the AMD side is Magny-Cours, which will definitely not be coming to desktops, so there's pretty much no chance of that happening with Beckton either.
