Intel 865 PERL Thermal shutdown
Deity
Well guys here I am asking if anyone has any experince with this problem I am having. OK First off I own 2 of these boards(Intel 865 PERL). Only having the issue with one. My system specs are in my sig.
My machine will suddenly shutdown (hard power off) and when it comes up it gives a beep code and says the system has shutdown to prevent damage to the CPU, something about a Themal event (over heating)
I installed Intels Active monitor and I also have a hardware temp probe butted up against the CPU under the heat sink (not in between the two). Both register temps between 85 and 117 degrees F. both within 2-3 degrees of each other. The heat sink is a Aero Cool heat pipe type with 80mm fan. At first I thought there might have been an issue with the heat sink. I took it off and installed an older Thermal take, replaced the Thermal paste etc. It is making good contact with the CPU etc. No Joy.
This thing has gone into themal shutdown while I was looking at the active monitor being around 85 degrees. I know its not over heating. I should also mention that I have had this board for the better part of a year with no issues with it what so ever. I went ahead and flashed to the newest bios thinking mabey a bug had surfaced or whatever...no change.
OK here is the kicker. This thing does not shut down while I am gaming when temps are the highest, but always tends to do it when I have finished a gaming session. CPU temps are dropping quickly and then BOOM, its off. Seems to do this about 50% of the time when exiting out of a game.
Anyone seen issues like this? Please offer any helpfull input you might have. Im affraid my board just may be borked.
-Aaron
