intel 530 vs plextor m5m for mSata replacement?
wkearney99
I've an Intel 80gb 310 (ssdmaemc080g2) mSATA drive in a T420 laptop. I'm running out of space on it. There's a 2nd 500gb regular drive for all the big storage, but the boot, OS and programs are creeping up a bit too close on the 80gb (less than 2gb remaining).
I'm leaning toward either an Intel 530 180gb or a Plextor m5m 256gb. They're both relatively close in price and, honestly, blistering performance isn't really a big priority. I just want to to be reliable and run faster than spinning rust. The 310's done an acceptable job for the past 2+ years, but it's time to upgrade. I just want to retain the same level of performance and reliability. A bit faster would be fine, but honestly not "necessary".
So, which drive and why not the other?
After looking around a bit it looks like the msata port in the t420 is a 3gbps port rather than 6gbps. Performance wise because of the sata2 limitation you won't likely see much difference between the two drives. Plextors are good drives and there is absolutely nothing wrong with them, likewise the intel drives are good drives. If for some reason you do end up with a warranty issue I know that the intel warranties are incredibly easy to deal with and do tend to offer cross shipping for their advanced replacement options.
Get the bigger capacity drive. Both brands are great, so that is a non-issue.
Any reason why the Crucial isn't in the selection (question goes to both the OP and people following up :)).
Plextor have good rep and extra storage, but the Intel one has 5 year warranty which is nice too.. decisions decisions..
