Hello everyone.
I got 240GB Intel 520 series ssd.Before installing windows I turned the AHCI mode and started to installing.(before installing all I have done is that) after that I made some settings for ssd as you know.checking trim, closing defrag and prefetch etc.
and then I run the as-ssd.but I think the score is too low for this ssd.I also try the atto.It seems logical compared to as-ssd.
System:
M5A97 EVO R2.0
FX-6300
G.Skill Ares 16GB 1333 CL9
GTX 660 ti
WD Caviar Green 3TB [configred GPT format]
Seasonic X-750
For amd system many people say that windows driver is greater than amd driver.so that's why I didn't install amd driver.
What should I do? Should I install my mb sata/ahci driver or whatelse?
Btw, if I install amd driver. do i need to format the system again or i can continue?
Thanks.
System:
M5A97 EVO R2.0
FX-6300
GTX 660 ti
Seasonic X-750
Thanks.
