Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Any thoughts on the Intel 510 Series (Elm Crest) SSDSC2MH120A2K5 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD). I am planning on using this one as a OS drive in my new build.
Pretty fast and reliable drive. Sandforce based drives are certianly faster but they seem to have reliability/bsod issues. Some people are problem free others are having chronic issues with theirs.
Another to consider is the Crucial M4, specifically after the *09 firmware. The M4 and 510 share the same controller if I'm not mistaken but the firmwares are difference hence the different performance.
I have four of these and they all work flawlessly. I also have one M4 that I have been extremely happy with. If I had to do it over again, I would probably opt for all M4 drives in order to save a little $$. It seems to be on par with the Intel performance wise, the reliability also appears to be comparable, and it is 20% to 25% cheaper (on sale).
