I used to be a good oc'er lol. Then I took about 5-6 years off of the hobby and am totally behind the curve with this.
anyway setup as follows:
2600K
Swiftech apogee watercooling setup with dual radiator-decent setup overall
Asrock Z77 Fatality performance motherboard
Mushkin redline 1866- 9-9-9-27 ram modules--4x4 gb sticks
Asus 670 Nvidia graphics card.
Mushkin 120gb SSD for os/boot, Samsung 500gb data drive
Mushkin 800W PSU
So rig runs well at default and mild overclock up to about 4.5-4.6ghz. Only about 1.325v needed for 4.5ghz. Past that things get dicey. I need 1.4v to get 4.8ghz booting and pll is at 1.8527 I think. It's OS stable and most apps, however prime95 causes memory dump blue screen after about 5-10mins. I've tried tweaking the vcore and the pll, but the other's I'm leaving pretty much alone. Speed step is still enabled as I do like it to throttle down when not loaded. Load line level is set at 1(most aggressive I think) and holds very well and actually volts up just slightly under load vs idle.
Just wanting some feedback on what you all think I could try tweaking. More vcore, pll, vtt ????? I think I'm close, as the IMC seems to be the culprit for the stability issue. I may back off later, but I'm a bit stubborn and want to figure out what I can do to try to stabilize this setting. I was hoping for 5ghz on water, but that looks like it's not going to happen, but 4.8ghz isn't too shabby. Hell even 4.5-4.6ghz is a decent upgrade over my older i7 920 @3.6-3.8ghz I was running prior(on same water setup).
BTW the Fatality performance board seems great. Nice bios, and seems very fast. I had to pull the Biostar Z77 x3 as it had the intel reboot loop issue so I have to RMA that one
2600K
Mushkin 800W PSU
