tiebird321
- Jun 6, 2004
hey is anyone else having issues with SP2 and the 2200BG card
if i put my lappy into standby or hibernate
the card is unusable until i restart
listed as disabled....
if i try to enable it it does nothing
i did a quick reinstall of XP SP1 on an extra 5gb HD i had sitting around and the problem does NOT occur under SP1 or after any update
the beta RC2 of SP2 did not cause this problem
but gold (public) does cause the problem
using latest drivers from intel, or 1 gen back
firewall is OFF
firewall is OFF
