So hear me out as I'm only just starting to understand how far alternate cooling systems have gone in the last few decades.
The problem is now with the current and predicted gpu roadmaps, air cooling will simply not be able to keep up, especially in the data center rack where all these are densly packed in.
So now there's an entire niche industry of companies that make immersion cooling, targetted immersion, AIO coolers, cooling blocks, and more just for servers. The light shines on the old idea of immersion cooling because it is the most efficient, but then there are other companies that use blocks to 'immerse' using cooling loops and then bathe the motherboard versus full immersion to make retrofitting an existing center easier with nearly the same benefits as full immersion.
But what's the next evolution? As the density of the chips increases, the cooling demands will in theory at some point outstrip even what immersion can do because of the local hotspot create by the core of the chip. Then what?
So my thinking is this--why are we trying to pack in so much into a chip and then taking such pains to get the generated heat removed? Why don't we just make the chips less dense with integrated cooling channels? Like how we cool a nuclear reactor core.
So a chip isn't necessarily a small thing anymore, but like a cube with channels in it where in an immersion cooler, the coolant is many times more efficient. And while the lack of chip density would reduce performance on some levels, being able to crank up the Ghz because of the integrated cooling should be able to push it above the current model of dense chips and then a cooling solution.
Curious to hear thoughts and other ways to push out into the future of all this stuff.
Because the future is nearly here.
