Integrated graphics and dedicated graphics running at the same time?
Darundal
Ok, I am trying to get my motherboards integrated graphics chip (915g) to output at the same time as my dedicated graphics card (x850pro). I have the card running my primary monitor and my tv, and want to get another monitor going on the integrated. I have tried to install the drivers for the integrated graphics, but they refuse to install. Anybody willing to help?
x850 should be dual headed. Do you have your tv running off of one of the dvi ports?
There is usually an option in the bios to have onboard video or the agp/pcie port turned on. I don't think it is possible.
I could be wrong though.
you can't run them both at the same time. at least comming from what i've seen. doesn't the x850 come with dual dvi and one s-video?
Mine has one VGA and one DVI, as well as tv out...but in the manual it specifically warns against using both the TV and a second monitor at the same time (which of course I promptly ignored) but when hooking both up and attempting to run both at the same time only one is recognized. I checked my BIOS settings, but there was nothing about disabling the onboard graphics.
In BIOS's with onbaord video, they will give you (sometimes) the option of disabling onboard video, or stting it to automatic. The way the chipset works, is that it will detect a Video BIOS installed in the system, and will promptly turn off the onboard video as a result. As far as I know, there is no way of getting onboard video and a video card to run at the same time.
