Feb 28, 2007 #1 B brysig228 Gawd Joined Feb 27, 2007 Messages 573 Anyone installed fan on their case cover? i was thinking of cutting a hole on the cover and install a fan so air can get it from outside. anyone done this if so what tools did you use to cut a hole with? thanks for your help.
Feb 28, 2007 #2 S Sta!nless Gawd 2FA Joined Dec 5, 2005 Messages 686 Start here.http://www.hardforum.com/showthread.php?t=758609 But in short, you can use a dremel or a hole saw. Just be careful.
Feb 28, 2007 #3 A Arcygenical Fully [H] Joined Jun 10, 2005 Messages 25,066 Hole saws or Dremels are the easiest to use. Go slow, and measure twice.
