Insufficient power question
slinky317
I recently purchased a new EVGA 9800 GTX+ (which I guess right before it was EOLed, being that my model is no longer on the EVGA website) and plugged it in last night to my Corsair CMPSU-450VX power supply. When I started up the machine and installed the drivers, everything went fine until I got an "Insufficient Power" message, saying that either the power supply was not enough or that one of the PCIe power cables was not plugged in.
I shut off the computer and opened it up, and saw that one of the power cables didn't seem to be pushed in all the way (barely), so I pushed it what little bit further it could go in and restarted the machine. I have yet to receive another insufficient power warning, so does that mean that everything is running fine? The PCIe power adapter took some fidgeting to plug into my 4-pin plugs, but I think everything is running OK. Is there any way to ensure that the card is getting the power that it needs?
Sounds like you found and fixed the problem. Not receiving insufficient power warnings is how you ensure the card is getting the power it needs.
