Instant zoom in game
FatboyHK
Is there any tools that let you zoom in while playing game? For example if I am running 1600 x 1200, I press the zoom key, the 800 x 600 pixels in the middle will be enlarged by 4 times and displayed
I know that are some "magnifying glass" tools that works on desktop, but I need one that can work with games...
I tried to ask about it in General Gaming forum but got no result yet, so I ask here.
ok, whatever, I give up arguing.....then where can I find a tool like this?
I used to have a good one for cs quite some time back, but it was only exclusively for cs or other HL mods. I think it still works because its not considered a cheat, its just a script bound to a key. What can can do is try to make your own script as well. Just make the FOV change to a smaller number, and that is your zoom.
oh yea... www.unknowncheats.com ahahaha.
FOV won't help in my case. The game I will use this tools for is Pacific Fighters. Planes that is far away is displayed in 2 pixels, and if I run at 2560 x 1600 there is no way I can spot them. FOV will enlarge nearby objects only.
I can use lower res but it is such a waste for the LCD I have isn't it?
