Installing XP64 on a nvRaid 0
ThrawnFile
Now that I've tried both regular XP, and the 64 bit edition that I downloaded on the nvraid and SiL SATA headers with no progress-I'll ask for help.
I can boot and create raid sets on either of the controllers, but when it comes to suppling the driver for XP to install, it cannot find it. I've used the ones on the CD that came with the ASUS A8N-SLI Dlx and downloaded drivers from both nVidia and ASUS. 64bit and 32 bit. None will take.
I'd really hate to have 2 74g raptors just being all normal, as I'm not afraid of data loss (spare drives and dual layer DVDs are for backup) And I'm pretty set on using the x64 version so I can sell my unused legit xp key with a comp that I am building for a co-worker.
Can't even enjoy the dual 6800gts I have, and it's been a couple of weeks now.
If your using a bios later than 1002m the nvidia (not sure about sil) sata drivers will not work. Download the latest from nvidia, make your own driver floppy. Now, when you start windows install, don't put the floppy in the drive (for some strange reason this corrupts the driver, even if you write protect the disk), press F6, wait until your prompted to insert a floppy into the drive, and presto, should load no problems.
I've done this several times for both xp32bit and 64bit.
The problem is, that windows setup cannot find any drivers on the floppy.
I've given up for the time being. Another odd thing is that when I go into bios, and attempt to change the (auto/normal/sli) mode for SLI config, it locks up. This didn't happen with 1002, but I flashed it to 1004.
Given up on the RAID 0 install that is, works just fine installing to a single drive.
