Installing Vista on second hdd, need help.
Xorg
I have windows xp on my 160gb hdd, and I'm thinking on installing Vista on my secondary 200gb hdd. My question is, will Vista replace all my files on my secondary hdd and reformat it or will my files be intact. Also when trying to install it, it gave me a message about my previous windows being moved to a folder called windows.old, is this the option it should give me to be able to dual boot xp and vista?
All of your other files on the 2nd hard drive should remain intact providing you do not partition or format the drive. Do not perform an upgrade installation as that will affect your Windows XP install. Simply start a regular installation onto the 2nd drive. It should go pretty smoothly and when you boot your computer you will get a menu that says "Windwos Vista" and have an option of "Earlier version of Windows".
Very Important. These disks/partitions must be set to be basic disk rather than dynamic disk.
That did not work for me.
I think you have two options.
The clunkiest (but safest) is to simply disable your drive with XP in BIOS and install Vista on another drive...you'll get no boot option screen but XP will be totally intact and safe.
The problem is that Vista uses a totally different bootloader- no more "boot.ini" to edit.
If you perform a "boot from CD" install of Vista with your XP install in place, not only will Vista NOT recognize the XP install, you won't be able to access XP anymore.
If you want to dual boot your system you must install Vista from within XP.
With XP running, insert the Vista DVD and begin the install, pointing to the partition you want it to inhabit.
About 45 minutes later, you'll have a boot screen that offers Vista and the "legacy OS" to choose from.
To edit/reorder/remove the Vista bootloader use
Vistaboot Pro.
Have fun and good luck.
