installing vista on laptop License Key problem
Sarge.
I'm trying to reinstall vista home premium on a toshiba laptop but its not excepting the vista license key that came with the laptop. Could this be due to using a retail disk when installing? I had throught all the disk where the same with vista.
Yes, that is precisely the reason, as I've been telling people for years now but always get told I'm mistaken. :) Retail media is not the same as OEM media, and that COA sticker and the Product Key on it will not let you install a legit license of Vista on that OEM branded laptop. You'll need to use the key that came with that Retail disc.
Install the same os as what is on there, using no key. Call MS to get them to let you use the OS key on the laptop
You need an OEM disk. You cant call MS and get them to let you use that key with a retail disc, it doesnt work that way. At least MSDN keys are retail now and not an additional key type..
In what way is it not accepting it?
As it does not activate online and asks you to call. That is expected and they will activate it for you.
The retail media is perfectly fine for an OEM key for Vista (not XP).
Edit:
It is too late now. But, you could have recovered the key from the pre-installed Vista (using jelly bean or whatever tool). If you used that key, you wouldn't even have to call.
But, either way, the retail media is fine.
I thinking it may need sp1 as the only disk that did work was a oem x64 sp1 disk. I found a RTM 32-bit oem that did not work.
I installed Vista home premium on a Toshiba laptop using a retail Vista DVD pre SP1 and it worked perfectly fine.
You still have not explained what did not work for you.
Edit:
I am sorry, it was not a Toshiba. It was a Compaq.
As in it won't accept the licenese key. It came pre-installed with sp1.
How does it not accept it!
Do you get a message?
I want to help you. But, can you provide a little more detail?
The only thing I can think of that can cause that is if you selected the wrong version during install.
You should either enter the key during the install. Then, it knows what version it is and will not ask you what version you are installing.
Or, if you don't want to enter the key during install, you have to make sure you select the version you have the key for. Are you sure you selected the right version?
You can check.
You don't ever need to put in the key during the Vista install, and there's really no reason to do so. You should always finish the install and get your drivers loaded, etc to make sure you don't have any issues before worrying about activation. Just be sure to select the version of Vista that you have a license for. I've done 5 laptops now using my retail Vista SP2 discs using the OEM keys, and all but one activated fine. The one that didn't only took a 5 minute call to MS to get it activated.
The license is being rejected before I even select which version of vista so its not that. It only so far has accepted the key with a oem x64 sp1 disk which i can't use as i need 32-bit. I have tried installing without a key (selecting the right version for the key) which works but it still doesn't accept it when I enter it in later. I tried a slip-streamed oem 32-bit sp1 disk but that had the same problems .
Do you have a non-slipstreamed 32 bit OEM disc?
Is the key on the sticker clearly visible? Are you sure you are entering the key correctly?
Use a magnifying glas to make sure.
Where did you get the Vista DVD from?
Is it a VLited Vista?
He said the key works on a OEM 64 bit disc. From what I read here, he's only tried a 32 bit OEM that has been tampered with. He needs to get a hold of a 32 bit OEM disc without stlip streamed SP1.
Yeah i actually tried one of those without a service pack and it also didn't work. Only thing I haven't tried is a 32-bit OEM with sp1 that has not been slip-streamed.
Well I fixed it, installed it without a key and installed the service packs then crucially put the license in when connected to the internet. Seems it something to do with some crazy volume license thing rather than it being just oem.
