Hi,
I'm planning to install my sp-94 with arctic silver 5. Am I using the right thermal compound?
Here's what they say on the arctic silvers' instructions (http://www.arcticsilver.com/arctic_silver_instructions.htm)
'Cause on thermalrights' insctions it says I should put a thin layer ont the HSF(which think is the heatsink) and the IHS(which I'm assuming its the CPU's heatspreader).
I'm not quite sure where and how to put the arctic silver.
Any pointers/advice would be much appreciated.
Thanks!
And here's what it says on thermalright's website :On an Intel P4 type CPU with a large metal heat spreader, put a small amount of Arctic Silver onto the center of the heat spreader as shown in the photo.
As I understand it, arctic silver says to pur a small amount in the middle and putting the HSF on it will spread the arctic silver evenly (which seems quite natural). But would that be enough?Put a thin, even layer of thermal grease on both the IHS and HSF base.
Thanks!
