installing SATA on the NF7-S
how exactly do i go about doing this? i got the floppy but i didnt know how i was supposed to get the stuff from the floppy to my rig. do i need to mess around with anything in the BIOS?
also, this is for the IDE-->SATA adaptor, my HDD is currently slaved so when its in its SATA goodness it can be master. i wish it could just be plug and play:(
help me please!
uh, are you reloading your system?
because then you'd just hit F6 at the prompt,
otherwise
load into windows, install the drivers like you would any other, and reboot
im sorry for being a little n00bish but im new to installing from the floppy, and i couldnt find the file on it that i was supposed to install
and, will i have to install drivers and then convert to SATA or convert first then install?
You need to go into the folder for the serial ata controller you have on your board (odds are silicon 3112) and then right click on the .inf file and hit install. If you are reinstalling windows entirely, boot from the windows cd and when it is doing all it's startup stuff hit the F6 key and then it will ask you to insert the floppy and it iwill find the drivers on its own.
