installing samegnome
The_Bob
I downloaded a bunch of gnome games from softpedia.com and it gave me a bunch of weird files. all I really am intrested in is samegnome but I guess I have to compile them and I have no idea where to start.
heres the link if someone wants to look at them and tell me what to do. thanks in advance.linky
I'll assume that you've got linux and gnome?
If so, it should be enough to extract the file you got ("tar -jxvf filename.bz2" , or "tar -zxvf filename.tar.gz"), enter the directory it created (cd gnome-games-2.10.1), and doing "./configure" and "make install". I wouldn't be suprised if they added themselves to the gnome menu.
Most likely, there's already a package for your distro, so you can "apt-get install gnome-games" or "emerge gnome-games" or find it in synaptic or whatever.
If you use windows, however, I'd just give up. It's definitely possible, but requires playing with cygwin. (Theoretically, you could use SFU and a separate X-server instead.)
