Installing Paxmate?
Carlosinfl
Loves the juice
I am thinking about laying down some Paxmate in my Antec P182 case and have never done this before. I was wondering when it does arrive, how hard is it to cut to fit? I would assume you simply cut the exact pieces you need before removing the adhesive side but I have never used this before so is there a tip or technique for this?
Thanks in advance...
I would just cut them to size before removing the adhesive as you said. I wouldn't remove the whole adhesive side at once though... I would remove it as you go to avoid mistakes especially on larger pieces
