I reformated Win 8 this evening, installed the built-in Killer NIC drivers on my M87 Mpower Max, and everything worked fine briefly until a few minutes later when I noticed I could not only not connect to the 'net, but I couldn't access the router (six week old ASUS RT-AC66U) through my browser.
Noticed this behavior on my laptop when connected via ethernet (using different cable) as well. Laptop can connect to the router via browser if I use wireless connection, but it can't identify my internet connection (which is working fine, I'm using it to type this with the modem just plugged straight into my desktop).
ASUS had me reset the router to defaults, try different cables, etc. Only thing I noticed strange is that both computers would stall when trying to disable their network adapters until I removed the ethernet cables.
ASUS thinks the router's ethernet ports are bad and wants to RMA it. But 1) isn't it a weird coincidence this happened right after I installed network drivers? (I realize that shouldn't affect the router in any way, but it's still strange) and 2) is it normal for all the ethernet ports to go at once? (this considering the router apparently doesn't see the modem or my computers)
