Installing new motherboard question
El Diablo
Everytime that I have ever installed a new motherboard on a system that already had windows installed it doesn't work. There is always a blue screen with some error message on it. Is there something special that I have to do. By the way I am changing out the motherboard, the video card, the ram, and the processor, but I want to keep the hard drive the way it is because of some data on it that is annoying to move and backup.
Well, for one, you have to roll back the drivers so it doesn't try using the old ones with the new hardware. Also, you can reinstall XP on the drive without reformatting (I wouldn't suggest this, but it is better than nothing). so... roll back drivers -> Reinstall XP -> get new drivers.
it is not recomended that you just switch out the drive to a new system. If its a must, then i would go into your hardware properties and delete damn near every system driver you can before the computer stops working (you shouldn't use a usb mouse). once you delete everything, or the computer stops running because you deleted all the system devices, turn it off and switch your board. When you turn it on with the new hardware it should detect all the new stuff. When you switch a mother board its a big deal to the OS, its not like a video card or something simple.
start a clean install. after it loads all legacy drivers, windows asks you if you want to do a install or a recovery. you want to do an install. the comes a eula, where you press f8. on the next page it asks you if you want to do a recovery (restore?) install again. this time answer yes. it will leave your data and apps alone, and replace all system files, including drivers. it will take as long as a clean install takes. you will have to reinstall some of your programs, since it also inits the registry. when my customers decide to "upgrade" their systems and fuck up their winxp installation, i do this. saves me from having to copy their files to another/external drive and reinstalling everything.
Oh does it? That's good to know...
Though, this is basically what i said in the first reply just.... not as step by step :D
Reformat. Before you do run the windows backup.
Windows backup in in the original XP CD but doesnt load by default on XP Home.
I Back-up to an external drive, reformat, load new drivers, then replace the back-up files and any programs that were lost. Its very easy.
umm:
El Diablo said:
...I want to keep the hard drive the way it is because of some data on it that is annoying to move and backup.
He's kind of asking to not have to reformat here. Your solution is assuming that he has another hard disk to back the files up to. While I would normally reccommend him reformatting, solutions that don't require other things than what he has is probably from which we keep our suggestions limited to?
