Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
How do you guys install new blocks or replace rads/res in a working system? do you use clips to shutoff that part of the setup? or do you drain the sytem?
I drain. Matter of fact, I swapped CPU blocks about two hours ago. Upgrades and additions are a convenient time to flush out any badness lurking in the water, refresh the anti-corrosives, switch to a different color dye.
Actually, I sorta drained. I did clamp the tubes to the rad. That way when I unmounted the CPU block and pulled the tubing of it, the reservoir wouldn't overflow with the water that would have been liberated from the rad.
I myself just drain , though I guess it could really depend on what you want to try and do. I'm can be a klutz sometimes so I'd rather just be safe then sorry.
