Installing motherboard
When installing a motherboard, do you put those brown paper disks on the screws? They are generally on the mb screws when you first open the bag. I would think not, wouldn't you need contact with those metal circles aroudn the screw hole to ground out you mb? I saw someone with a plexi case ground out their mb like that.
I don't think it matters really. I don't think there's a metal to metal contact with the screws and motherboard either.
