installing mobo
r3m3dy
hi i am currently trying to install my dfi motherboard and i was wondering why i see these little metal tabs when looking at the sound connector, usb ports, mouse port, etc. should i tuck these in or should i remove them?
that is what i am talking about but the only thing is they don't seem like they are removable. one for instance is blocking partially my port for the mouse. how would you suggest i remove them?
Just bend them off to the side. You don't want any sharp edges hanging on around there.
