I am having Thermaltake Armor MX Case and would like to install LED Lights strip (NZXT Hue) on all the four sides/corner of the case.
Now there are two obstacles that is preventing me to install light strip on all four corners:
1] The exhaust fan at the back is blocking the way of the strip (See image) --> http://tinypic.com/r/11kytc6/6
2] There are lots of plastic bumps at the front which will prevent strip to sit flush (See image) -- > http://tinypic.com/r/20qlp3/6
And finally the length of the strip is 2Meter so there would definitely be some remain unused, so can i cut it ? OR where to tuck away rest coz they would give lots of light effect at one place and ruin the overall effect of the case.
