Okay, I have 4 IDE devides I need to install..
HDD
HDD
DVD-ROM
DVD-RW
My friend told me that if I put the two HDD's on seperate channels, I'll get a slight performance boost, since IDE cannot read and write at the same time...having them on different channels will allow simultaneous read/write hard drive access. This sounds good to me. However, my question is, if I have data on the secondary channel, and my DVD-RW drive there, what happens when I'm burning data from the HDD to the DVD-RW on the same channel? It cannot read data from the HDD and burn data to the DVD-RW at the same time, so will it impair performance? What's the optimal configuration for best overall performance? I know most OEMs put the HDD's on the same channel, but should I do that?
HDD
HDD
DVD-ROM
DVD-RW
