I don't need to make custom cables, just have to put the connectors on pre installed cat 5 cables.Darkstar850 said:For the most part, unless you need custom lengths, making cat5 yourself really isn't worth the time. I do have the cabling, jacks, and tools myself, but once again I use it only for custom cables. Cables on line are damn cheap anymore, although still horrible in retail stores.
Dan17 said:You can buy any type of RJ45 end connector, it really doesn't matter. They are about 40 cents each. You will need to buy crimpers though. The price range could vary from 15 to 25 bucks.
Guide:
http://www.duxcw.com/digest/Howto/network/cable/cable5.htm
...It looks a bit complicated but you can do it. First, you need to decide what type of cable you need:
Crossover- pc to pc, hub to switch, xbox to xbox
straight-through- pc to hub, pc to switch, pc to router
either- router to hub, router to switch
Then find the diagram and begin ordering the wires as shown.
Hope this helps,
...Dan
