Installing Angular where I want it to go
Xarzu
The Angular lesson I am watching is showing installing from bash (I assume because it is on an apple computer) with the line:
npm install -g @angular/cli
So, since I am a poor windows user, I have done the same on powershell.
and it puts everything on my C drive under AppData\Roaming.
So my question is this. Is it possible for me to put all this on another drive? My C drive is getting full. So how do I effectively also delete angular as well?
If you dont' include -g it doesn't install it globally and will put it in the folder you're working in.
I think that's a node package manager setting to change the global folder.
