Installing an additional case fan
ksanders2006
Ok, so the case I bought came with one 80MM fan. It said it had room for 4 more, but i dont know where they go. I bought a coolermaster 80MM and i dont want it to go to waste. Any help is appreciated
-Kenny
What case is it?
Should have places inside front and inside the back of the case.
it should have little "cheese-grater" holes where the fans should go.
they'll look like little sections of your case that are pock-marked usually in a pattern with dots.
You want at least one blowing in front bottom and one blowing out back top; power supply fan doesn't count.
