Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
If I am using my motherboard sound, I want to install a sb audigy zs. Do I need to uninstall the drivers for the onboard sound or can I just install the board and use the board
Depends how careful you want to be. I've installed it over my onboard and had no problems, but nobody recommends it. It depends on how easy it is to install and reinstall your onboard sound and whether you plan on using it: if you don't plan on using the onboard anymore, you might as well uninstall it: taking up harddrive space. If it's a snap to reinstall, you might as well uninstall, install the audigy, and then reinstall the drivers: it's safer. If it's a pain to reinstall, just install the audigy over it and hope that nothing happens.
