A Great friend to the HardForum with a great kid that he is trying to get a scholorship to continue his schooling. Please give hime a vote! Only 24 hours left! Thanks.
I don't know about SATA drives, but certainly on IDE drives, there are a set of pins that you need to bridge with jumpers... Usually, there should be a small picture on the HD itself showing what "Primary Master", "Secondary Master", "Primary Slave" or "Secondary Slave" configurations are.
Yes, you will need that to install the drive. The fastest way to get the SATA drive to boot as the Master is to pull the power from your other HDDs. If this helps at all I had to enable the RAID setup in my BIOS just so my single SATA would boot right.
well i got windows on it before you suggested unplugging the other drive. i didnt finish setup, and i didnt even hit F6 before installation of windows.
i just want this thing to be the master ... yet it reads slave. do i just not worry or what
