Installing a new MB -help-
Skooongie
Can you guys help me with the steps?
I've never installed a new MB, but I am pretty sure I can do it. I just want to double check the RIGHT steps I should take before doing it.
I don't want to lose any data etc.
Thanks guys
You need to make sure you are working in a static free area, any stic charge to certain components on your mobo and your doomed! I'd google : how to install motherboard -or- install new moitherboard step by step!
It would also be in your best interest to read up on the manual. Most motherboard manuals should already provide pictures/descriptions of the parts you will be needing to plug in, such as the power cables, the ide cables, floppy cables, pretty much the motherboard orientation.
SR45 posted a real good link ^^
Ah... brings back memories of my first install... I was so worried I was going to break something... or mess it up with static electricity.
The best advice I can give you is to just take things slow and don't rush. You don't want to break something, but also, don't be too overly cautious. You'll do just fine and good luck on that mobo install buddy!
You cant expect to install a new motherboard and run the same install of windows from the existing hard drive.. unless its the same motherboard you need to wipe the system.
Actually.. you can... but you will have stability issues and some hardware/software will not function properly as it was meant for the original install, so of course it is recommended to wipe and reinstall windows. I've done just that to an hd from an evga 680i mobo to an asus maximus formula. Also had done that from an Asus K8V se deluxe to a DFI lanparty UT SLI-DR.
I wish there would be a STICKY guide here that would help the Newbies build new systems.
Yes you can do it on the same chipset, but without any information from the op about the motherboard he was moving from and too, its a no.
There are plenty of guides around the internet, but the forum is here for a reason, the stickys don't come from nowhere, why don't you write one and submit it to a moderator and maybe it will become a sticky.
It may just be luck of the draw, or just doing it carefully, but there need not be any problems whatsoever. I changed the entire platform: went from a nForce4 SLI chipset (socket 939 AMD) to an Intel P35 chipset (socket 775 obviously), and I had no problems with my XP install. Zero, zip, zilch. Everything worked just fine, and I didn't even have to do a repair install, just uninstalled the old nVidia chipset drivers and installed the new Intel chipset drivers. It's been over a half a year already, and no problems have crept up, and I doubt they ever will. Still 100% rock-solid stable. I don't know what people must be doing differently than me, as I fail to see where the problems are coming from.
(Disclaimer: Back up first just in case, and I do not doubt that some people have had problems; I have a feeling they're more rare than people think though, as people that post tend to be the ones who are having the problems.)
Every time i tried it it either froze on the windows loading splash or i got a bsod, its not worth the instability issues that will most likely occur, and any possible performance hits.
Not sure about the BSOD's, but freezing on the splash screen can happen due to lack of storage drivers. For that, putting the SATA ports into IDE emulation mode changing the controller the drive is on (if possible) or using a IDE-SATA converter as a last resort can work. Then install the necessary storage drivers and put the drive back on the desired controller. That's in fact what I had to do in order to get Windows XP to work with AHCI; I temporarily moved the Windows HDD over to the JMicron controller, put another drive onto an Intel port in AHCI mode (as the drivers refused to install if AHCI wasn't enabled in the BIOS), and then installed the AHCI driver and finally moved the drive back.
Or if you can't (or don't want to) mess with the hardware side of things, that's a case where a repair install can work, but I tend to think that installing over an already installed system might be part of what causes the problems for some people.
Might give it a go next time im in this situation, but for the most part dont you think its just easier to do a format and install xp from afresh? i just have this thing about running software where it was never intended to be if you see what i mean.
If you don't have many programs or have lots of time on your hands, yeah I agree. It wasn't that hard to reinstall Vista, which I had to do anyway as I wanted to go from 32-bit to 64-bit. The problem with my XP partition is that I have so many programs on it that it would take forever to reinstall all of them. Then after reinstalling everything, I'd have to customize all their settings to be the way I them again. Not to mention download all the updates to Guild Wars and LOTRO again (that took enough time in Vista on my slow DSL connection). It was much less work just to keep the old install.
If you only have a few programs and haven't customized much, I agree that reinstalling is better though; it's just more clean. It's just not always practical to, and it's usually avoidable.
Why dont you just borrow an external hard drive from a freind? or buy one from bestbuy etc, use it and take it back for a refund.
