ShadowGhost12
- Oct 3, 2004
My computer has two drives, a DVD-ROM drive and a CD-RW drive.
I bought a DVD burner this past weekend, and am currently trying to install it.
I took out the old drive, and replaced it with the new one, hooked everything up the same way as before, and when I turned it on, the computer didn't recognize either drive now, not even the old CD-RW drive I never even replaced or tampered with. Also, booting up was a painfully slow process for some reason.
After doing some troubleshooting, I decided to pop the old drive back in, and take the new burner out to see what happened, and the machine booted up fine, both drives were recognized with no problems.
I'm not sure whether the drive requires different hook-ups or what, but before the DVD-ROM drive and CD-RW drive were hooked up with a ribbon cable, and an IDE cable, nothing else. Everything was supposedly hooked up to the motherboard and power supply, etc. properly by the manufacturer, so I didn't tamper with that, I just took the two cables off the original drive, popped the new one in, and attached those cables.
This is my current situation, so if anyone can help me to guide me on where I could've gone wrong, that would be much appreciated!
