agreeddjnes said:Run a spyware scan, and clean any malware off before trying it again. Or, for better results, slipstream is into your XP CD using Autostreamer, and do a fresh install. Either way, you're asking for trouble if you don't have SP2 by now.
That could be the most ricidulous comment ever made on the forums. Take a look at the security patches included, and then tell us you don't need it.2Fresh said:I have not had any issues without it....so looks like I dont need it.
um, yeah, ok2Fresh said:I have not had any issues without it....so looks like I dont need it.
Seriously...that's like saying I don't need to wear seatbelts when I am in a car because I wasn't in an accident in the past.Ezekial said:um, yeah, ok
Old issues, yes, and all of what have fixes.[H]EMI_426 said:Check the MSKB. There's several articles relating to constant reboots after SP2 installs.
Wow. Maybe that's one of the main reasons I directed the OP to go take a look there...djnes said:Old issues, yes, and all of what have fixes.
Originally Posted by 2Fresh - I have not had any issues without it....so looks like I dont need it.
Originally Posted by djnes - That could be the most ricidulous comment ever made on the forums.
Whoops, I guess we were supposed to assume constant reboots were the only possible problem with SP2?[H]EMI_426 said:Wow. Maybe that's one of the main reasons I directed the OP to go take a look there...
I would hope he'd know to search for more words than just SP2. I'm not sure why you're bent out of shape. If he'd have done just a bit of digging in the KB he probably would have solved his own problem.djnes said:Whoops, I guess we were supposed to assume constant reboots were the only possible problem with SP2?
Which is why you miss out on the reasons why such attitudes are justified in the non-Unix sections. Spend more time in this subforum and you'll get it. I'm not dumb enough to make assumptions about what you may do for a living, but if you were a sys admin over a network of Windows boxes, you'd share my viewpoint as well, I'd think.[H]EMI_426 said:Attitudes like yours are the reason why I never post in the non-*nix part of the OS forum.
That's a lot more graphic than I had in mind, but it definitely gets the point across!GORANKAR said:I think what djines is saying is: If you are running Xp without sp2, you might as well keep a bottle of booty lube next to your keyboard, because sooner or later you are going to take the high hard one up the tailpipe
HA!Originally Posted by GORANKAR:I think what djines is saying is: If you are running Xp without sp2, you might as well keep a bottle of booty lube next to your keyboard, because sooner or later you are going to take the high hard one up the tailpipe
