So ya....I cannot believe I did something this stupid but like the topic says, I installed a 512mb stick of OCZ ram in backwards (went into the DIMM slot rather easy actually) but now of course im having problems. This ram stick is dead as far as I can tell, theres a black contact point on one side the stick and when I put it in a different system nothing happens. System starts but I get no beep and nothing appears on the monitor.
However I cannot tell if my mobo has been delt the death blow or not. The motherboard boots, atleast occasionally. If it does not boot flipping the switch on the back of the PSU and back on usually lets it boot back up. When I boot and actually see the BIOS screen I normally see overclocking failed but every now and then it will start up like normal, but then once it comes to load windows xp it has problems, I get to the screen saying that XP did not load sucessfully on the previous boot and asks if I want to boot normally or goto safe mode etc. I choose boot normally and then the screen will go blank and nothing happens. I've tried two different HD's, and both work perfectly on another machine. So its my mobo having problems, anyone have any ideas on how to fix this or is the mobo gone?
The motherboard is a Asus P4P800 Delux w/ an Intel P4 2.8Ghz. All other parts that where in the system when the "incident" happend appear to work fine, the power supply even seems to work like normal but smelled of burnt PCB when I first smelled it after the "incident". It still does smell but not nearly as bad, so I guess its going away. When using the PSU in another machine the machine works fine and the voltages hold at what it did before the "incident".
Would appreciate any suggestions on what to try next, if anything, thanks.
