About a month ago, i purchased a PSU from someone on the AT forums that was a reviewed PSU.
PSU - Tagan Silver Guardian X 1000W
For reasons that aren't important, i hadn't had an opportunity to install it until tonight. So after installing the new PSU, i turned the computer on and got nothing. Some LEDs tried to light up (on fans) and i thought i heard something trying to start - but nothing.
A mobo LED stays lit, as well as a red LED on the back of the PSU.
Knowing this was a reviewed PSU, i can't imagine that it would be defective. What could be the problem?
So far i've...
Double checked the PSU connection to the mobo (including the 4-pin)
Checked for 110/220 - no option on the PSU to change it
Switched the power feed to the hard drive with another one
Checked to make sure the outlet works
Shorted the power switch pins on the mobo
Maybe something else - i'm very frustrated and scared that i just lost $150
Here is my system:
Mobo: SY-P4I865PE Plus Dragon 2 (Soyo)
CPU: P4 3.0c (Stock Cooling)
RAM: 1.5 Gb PC3200 (3x512)
Video: BBATI X850XT
Sound: Turtle Beach Santa Cruz
HD: Western Digital 160 GB PATA
Optical: BenQ DVD-ROM (can't remember model), Generic 52x CD-ROM
Floppy: 3 1/2" Floppy Drive
NIC: Generic 10/100 NIC
Before, i had an Antec TP 480 attached to the system and everything worked just fine. I shut it down, took out the Antec, put in the Tagan, and nothing.
Can anyone think of something that i'm missing?
Thanks,
Chris
PS - i know the Tagan is overkill for this system, but i dind't really buy it for this system, i bought it for my next one i will eventually build and was simply buying the case and PSU early as those usually don't fluctuate too much in prices and can be used for a long time.
EDIT:
To update - i connected the PSU to another computer and got nothing there as well
OK - another update - i tested the PSU by putting an unrolled keychain (couldn't find a paper clip) in the green and black spots and when i plugged in the PSU the PSU powered the LED fan i had it connected to - does this mean the PSU is NOT dead?
So far i've...
Here is my system:
Video: BBATI X850XT
Thanks,
Chris
EDIT:
