weemanbran
- Dec 6, 2007
Ok, so I just purchased a Q6600, 4gb g. skill ddr2 pc6400 ram, and a DFI lanparty p35 mobo. I haven't ever build an entire PC before, just installed a video card, ram, and PS.
Mobo: http://www.newegg.com/Product/Produc...82E16813136043
Ram: http://www.newegg.com/Product/Produc...82E16820231122
CPU: http://www.newegg.com/Product/Produc...82E16819115017
To my surpise the first time I tried to power my PC it actually booted. It showed the DFI Lanparty logo then went to the black screen with PC specs that shows:
Main Processor: Intel(R) 2.39 GHz (266x9.0)
Memory Testing: 4193280k Ok
CPU Brand Name: Intel(R) Core(TM) 2 Quad CPU Q6600 @ 2.40 GHz
CIE BIOS Supported
Memory Frequency for DDr2 800 (Single Channel Mode)
IDE Channel 0 Master: None
IDE Channel 0 Slave: None
IDE Channel 1 Master: None
IDE Channel 1 Slave: None
IDE Channel 2 Master: None
IDE Channel 3 Slave: None
IDE Channel 4 Master: HDS728080Plat20 PF20A21B
IDE Channel 4 Slave: None
CMOS checksum error - Defaults Loaded
Warning! CPU has been changed
Please re-enter CPU settings in CMOS setup remember to save when you are finished
Press F1 to continue, DEL to enter SETUP
12/24/2007 - Bearlake - 6A790d4WC-00
When I click F1 to continue it goes to:
Lists of PCI devices etc
Verifying DMI Data..... Update Success
Backup CMOS.... OK!
And I can't get past that. Do I need to reformat my PC? I have tried multiple times, but I can never get the PC to boot to disk. I believe it has something to do with the Mobo only having 1 IDE slot. I noticed in the bios it is not recognizing my dvd/cd drive. Currently, I have 1 IDE splitter cord going from the Mobo to the hard drive then to my dvd/cd drive. Is there some way that the mobo can't handle 2 different devices from one IDE slot?
Any help would be appreciated as I am baffled.
CIE BIOS Supported
Backup CMOS.... OK!
