E6300 @ 3.5GHZ (1.36V)
Asus P5B Deluxe Wi-Fi *vdroop modded*
2GB TeamXtreme "D9GMH" 4-4-3-4@DDR1000 (2.25V)
74GB Raptor/300GB Maxtor Maxline III
eVGA 8800GTS 320MB [650/1000]/X-Fi XtremeMusic/Corsair 620HX
Lian Li V1000BW/Dell 2007FPW/Logitech G5/Razer Tarantula
NEC ND-3540A 16X DVD-RW Drive
Ok first I tried an upgrade from my current XP Pro setup
it works fine then it get to this screen and the computer totally LOCKS up
the mouse cursor won't even move
so then I try to boot from DVD and do a fresh installation, everything works fine but then I get prompted for this... I have no drivers for this and I went on the NEC website for drivers and they said the drive didn't require drivers. So now im stumped and I couldn't get past this screen.
I have also tried both on stock settings without an overclock, im about to pull my hair out
Can anybody help? I know I just didnt spend all this time for Vista if I couldn't install it..
