Ok so the problem i am havinf is when i try and do an initial clean install of either vista ultimate or xp pro. I get BSODs with either install the vista install won't even get into the installer, the xp fails at various stages during the install, but never finishes. I pretty much always get the error 0x0000000A, which i have read/found to indicate a hardware issue, generally associated with bad memory, but not always. I have run memtest on each stick for 9+hours each stick, no errors. I have tried installing with just one stick, as well as both sticks.
I have slipstreamed the XP install with SP3 and the RAID and AHCI drivers for the Motherboard.
The specs of the system are as follows:
Motherboard: Gigabyte EP45-UD3P
CPU: Intel Q6600, not OC'd
RAM: 2x2 GB
Video Card: Nvidia 9800 GTX+
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147130
I am really beginning to question the power supply. Everything powers up fine and seems to work, but i am not sure. does anyone have any experience with this PSU, how can i tell if it is the PSU without having to buy a new one? If i do buy a new one, how is this one: RAIDMAX RX-700SS
I would really appreciate some help and or advice.
Thanks for your help
RAM: 2x2 GB
