Install openSUSE from USB drive?
musky
[H]ard|DCer of the Year 2012
Has anyone been able to install openSUSE from a USB stick? I've spent a few hours now trying to get it to work without any luck. There is apparently something about openSUSE that makes it not work with bootable USB creators like unetbootin. I do not have a spare CDROM drive, so I can't just make a bootable CD.
I am trying to figure out a netwrok install right now, so hopefully that will work. Otherwise, I am distro shopping again...
Eh - wrong subforum?
I'm sure we've some OpenSUSE user around here - hopefully you can get the help you need.
Not really. I figured with all of the folders around here running openSUSE on dedicated boxen, someone would know how to do this.
That is fine if you already have openSUSE installed. I do not.
This is way more hassle than it should be....
Steal a optical drive from a boxen for the install and then plug it back in after the fact?
That's what I did until I borke down and got a Slim USB DVD drive. Now most of the systems in the house have no optical drive, but if they need one I jut plug it in.
Have no clue on the 'nix side.
One of these days...seems odd that I have thousands of dollars in computer equipment, but I won't break down and buy a $20 SATA CDROM drive... :) Believe it or not, I literally do not have an SATA CDROM in this house, and the ASUS board does not have an IDE controller.
For about $30 or so you can get a slim dvd rom from amazon. Make sure you get a DVD. Many OS need the space.
Love mine. Solves a bunch of problems.
Well, I give up. It was a complete no-go with openSUSE, and Fedora wouldn't recognize my hard drive. I did find an old IDE controller, but I couldn't figure out how to get a CDROM attached to it to boot.
BTW, what do you gain with slim drive? Space isn't a problem.
musky i have been trying for a week to get opensuse on my new box.....no go.
getting a slimdowned linux install to run F@H on this box is turnout out to be quite a challenge
portability, many of the slim drives do no require external power, so its easier to move from one box to another when you need to do an install.
This.
The one I got needs 2 USB ports. One for power, another for power/data.
So when I need to do an install, I just plug two USB wires in and I'm good to go.
http://www.pendrivelinux.com/
One of my favorite little sites for such things. Might help. You should be able to figure out how to make a persistant install. Without having to install linux on a machine you could load up a VM in Virtual Box or VMware. Virtual box is good stuff, and a little cheaper than VMware Fuzion. ;)
I couldn't get unetbootin or any of the other iso - to - usb proggies to work with openSUSE. This is something about a couple of the files needed for booting that don't work. There are several articles on it, but no particularly good solution that I could get to work. I think I am going to scrap openSUSE and try Debian.
I got it to work just fine. Unetbootin will download the distro for you and install it to the thumb drive directly. Though since I already downloaded it I was able to select "ISO" and install it that way.
I've only tried ubuntu though, so I can't really comment on opensuse's install on a usb drive.
Why were you looking at opensuse anyway? are there any features that it has over others that make you want it?
because ubuntu 10 doesnt work for F@H :(
Maybe there is a reason you haven't tried it, but Ubuntu 9.04 is reported to work just fine with FAH.
There's a few fixes for ubuntu 10.04's folding issues. but for ease of install get 9.04 for folding rigs. seems to be the best version for folding.
Yeah i tried those and it didnt work for me.
I have 9.04 Ubuntu on most of my rigs at the moment. 9.04 server doesn't work with unetbootin (it keeps griping about not having a CDROM and won't install), but desktop does.
The reason I am distro shopping is that 9.04 is a pretty old kernel, and I wanted to try something newer for non-folding reasons. When nitro asked a while back, several people suggested openSUSE so I figured I would give it a try. I finally got it installed in a VM, and I must say I am not at all impressed with it. It is just not very easy to deal with.
I just started playing with Debian Lenny, and so far, I like it. That may end up being what i go with.
Yeah, I use opensuse at work. can't say I'm too impressed. it's stable, yes.. and yast is nice for remote admining. I know my way around the linux command line well enough that I don't really need it. Yast also seems a bit bloated and in the end tends to make the computer/server that it's running on a bit slower then it could have otherwise been with a lighter OS like debian.
I really like Debian Lenny for servers if ubuntu server doesn't play nice :D
